Disable audit-trail for icmp packets in CBAC logging
filippos111
Hi folks,
I have a cisco 2811 router set up as a nat/firewall gateway for my network. I've configured it for CBAC on using ip inspect and an access list.
What I want is to use audit-trail to record network traffic (which means sending syslog messages to a server) concerning established sessions from my own network to locations in the outside.
If i configure this using ip inspect audit-trail and no ip inspect alert-off, the configuration looks like this:
Session audit trail is enabled
Session alert is enabled
one-minute (sampling period) thresholds are [400:500] connections
max-incomplete sessions thresholds are [400:500]
max-incomplete tcp connections per host is 50. Block-time 0 minute.
tcp synwait-time is 30 sec -- tcp finwait-time is 5 sec
tcp idle-time is 3600 sec -- udp idle-time is 30 sec
dns-timeout is 5 sec
Inspection Rule Configuration
Inspection name FIREWALL
    http alert is on audit-trail is on timeout 3600
    https alert is on audit-trail is on timeout 3600
    smtp max-data 20000000 alert is on audit-trail is on timeout 3600
    imap alert is on audit-trail is on timeout 3600
    pop3 alert is on audit-trail is on timeout 3600
    pop3s alert is on audit-trail is on timeout 3600
    igmpv3lite alert is on audit-trail is on timeout 30
    icmp alert is on audit-trail is on timeout 10
    ntp alert is on audit-trail is on timeout 30
    ssh alert is on audit-trail is on timeout 30
    sshell alert is on audit-trail is on timeout 30
    tcp alert is on audit-trail is on timeout 3600
    udp alert is on audit-trail is on timeout 30
    dns alert is on audit-trail is on timeout 30
which works just fine, but there is the matter of icmp packets.
Since i use polling software that needs to check some machines in the outside part of the network, it is only natural that several icmp sessions are established through the Inspection Rule per minute. The problem is that since these sessions are recorded along with everything else, my syslogs are flooded with these (since i am using logging trap informational) to the point that more messages are generated about icmp than all other traffic combined, especially in non-working hours.
What I am asking is a way for the audit-trail to be selecively disabled for icmp, so that the outgoing (echo) &incoming (echo reply) sessions can be established without generating syslog messages.
Thanks in advance.
johnlloyd_13
Level 9
Level 9
hi,
could you try in global config:
ip inspect name FIREWALL alert on audit-trail off timeout 10
johnlloyd_13
Level 9
Level 9
hi,
