Bookmark
Subscribe
2401
Disable Auto Save Configuration
PolarPanda
Hi all,
           Does anyone know how to disable auto save configuration on switch 3850? Now, I don't need to execute command "wr", the switch automatically saves configuration by itself after I exit from "conf t". My goal is to manually type "wr" in order to save configuration. Otherwise, I don't want to save any configuration no matter what I type in after "conf t". Thank you!!
7 Replies 7
balaji.bandi
Your question it self confusing, there is no autosave config automatically.
as per my understanding you do not like to write command, the config should save automatically ?
you can use EEM script for this to save config with different version flash:
if that is correct, read below thread yo help you - if not explain more,.
https://community.cisco.com/t5/network-management/eem-change-configuration-every-60-minutes/td-p/2322210
BB
Hi BB,
        Thank you for the reply. I just edited my post. I hope it's more clear now!
So now your environment auto saving the config on this device ? once come out from config t ?
BB
Yes, correct!!
Not sure what IOS XE version you have on this device :
look at below document to veriy you have any configuration done :
Performing a Configuration Replace or Configuration Rollback Operation
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9400_cg/b_166_sys_mgmt_9400_cg_chapter_01001.html#task_qhj_g41_m1b
or post the show running configuration to suggest better.
BB
Thank you for the link. It's very useful in the future. Here is version: Catalyst switch 3850 Version 03.03.03SE. Which part of running config are you looking for?
Post the current running configuration removing any confidential information.
BB
