Disable autostate feature on 6800 and C9300
patil.sah1
Does 6800 series and C9300 support autosate feature?
If yes, what are the commands to disable autostate on SVI on 6807 and 9300 platform
Reza Sharifi
It is enabled by default and I don't see a command to disable it.
Thanks Georg.
But the command switchport autostate exclude will ignore that particular interface status to determine the SVI state.
In my case, I need to configure only SVI and that VLAN shouldnt be allowed in any of the ports.
Is there any feature available in 9300 and 6800 similar to 4500 chassis, like we disable using "no autostate" under SVI
Hello @patil.sah1 ,
you can use a loopback interface to have a L3 logical interface with status unrelated to switchports if disabing autostate is not an option on SVI interfaces.
Hope to help
Giuseppe
