Disable Errdisable detection
sirajmuneer
Hello guys,
I would like to know if there is a function for us to disable errdisable state detection in IOS.
Normally any interfaces will go to errdisable state because of many possible causes such as duplex mismatch.
I am hoping to avoid the interface to go to errdisable state even if there is duplex mistmatch etc which for sure will bring the interface down.
Thanks a lot
SiraJ
mohammedmahmoud
Level 11
Level 11
Hi SiraJ,
You can simply do this via the "no errdisable detect cause x" command, but this is highly not recommended as it is a safety feature.
BR,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Hi SiraJ,
BR,
Mohammed Mahmoud.
cisco_lad2004
Level 5
Level 5
the below was taken from a 4500, duplex mistmach does not cause error disable. it will simply show up in log and cause CRC errors heavily.
Sam
ACC01#sh errdisable detect
ErrDisable Reason Detection status
udld Enabled
bpduguard Enabled
security-violatio Enabled
channel-misconfig Enabled
psecure-violation Enabled
vmps Enabled
unicast-flood Enabled
pagp-flap Enabled
dtp-flap Enabled
link-flap Enabled
l2ptguard Enabled
gbic-invalid Enabled
dhcp-rate-limit Enabled
storm-control Enabled
ilpower Enabled
arp-inspection Disabled
Hi Sam,
Duplex mismatch doesn't have a specific errdisable detection mode, but please take care of the following, i quote from this document "Errdisable Port State Recovery on the Cisco IOS Platforms":
"Link flap means that the interface continually goes up and down. The interface is put into the errdisabled state if it flaps more than five times in 10 seconds. The common cause of link flap is a Layer 1 issue such as a bad cable, duplex mismatch, or bad Gigabit Interface Converter (GBIC) card."
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
BR,
Mohammed Mahmoud.
