disable ospf on a specific inteface
carl_townshend
Hi all
I have a new link I want to bring into my network, But I dont want OSPF neighbours to be formed on the link as it will most certianly be used as its a lower cost.
How would I achieve this ?
Would I just use the passive interface command? or just not include that interface IP in the network statement ?
cheers
An example can be found here:
http://www.routerlabs.de/tutorials/ospf/redist/index.html
But I agree with Inayath, if you don't have good reasons to use redistribution, the passive-interface is the better option.
Best regards
Rolf
Rolf Fischer
Level 9
Level 9
Hello Carl,
you can either use the passive-interface command (no Hellos will be sent on this interface and thus no adjacency formed) or -without a network statement for the prefix- redistribute connected networks with a route-map for the desired network(s), in this case the route type will be external.
The route type could play a role in regards of filtering/stub areas.
Hope that helps
Rolf
hi
can you tell me how you would do it via a route map? can you pls give example ?
cheers
Hi Carl,
The best way is make the interface as passive interface. Or dont advertise this network into ospf domain hence there will not be ospf running for that particular interface.
Inayath
Best regards
Rolf
