How to configure internal VLAN ip routing?
shameer.vali
How to confiure internal VLAN ip routing?
InayathUlla Sharieff
Hi Shameer,
Please find link below which explains how to configure intervlan routing.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bf9a.shtml
Inayath
Hello
Basic intervlan routing config between core switch and access switch
Core switch:
(enable ip routing)
ip routing
(create switch vlan interfaces (svi) each vlan - lets say vlan 10 & 20)
vlan 10
ip address 10.10.10.254 255.255.255.0
no shut
vlan 20
ip address 20.20.20.254 255.255.255.0
no shut
(create L2 vlan in vtp database)
vtp domain TST
vtp mode server
vlan10,20
exit
create trunk interface for connection to access switch
int gigx/x
switchport mode trunk
set default route to external network ( if applicable)
ip route 0.0.0.0 0.0.0.0 x.x.x..x
Note:
I haven't included additional features like configuring stp/nat/static or dynamic routing
Access- switch
create trunk interface for connection to core siwtch
int gig x/x
Description link to core switch
(create switch vlan interfaces (svi) for connection to core switch)
vlan 10
description management vlan
ip address 10.10.10.1 255.255.255.0
no shut
ip default-gateway 10.10.10.254
vtp domain TST
vtp mode client
( vlan database should sync with core switch and obtain vlan information for 10,20)
assigned host port to designated vlans
int fa0/1
switchport host
switchport access vlan 10
no shut
int fa0/2
switchport host
switchport access vlan 20
no shut
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
