Disabling 3750 interface snmp traps
williamka
Level 3
Level 3
I constantly receive trap information on 3750 switch for interface up/down and would like to disable this notification. Is there some way to disable the notifications for workstation interfaces and keep trunk interfaces active? Thank you for any assistance
Configure 'no snmp trap link-status' on ports for which you don't want to receive link status alarms.
SW1-3550(config)#int f0/1
SW1-3550(config-if)#no snmp trap ?
link-status Allow SNMP LINKUP and LINKDOWN traps
mac-notification MAC Address notification for the interface
SW1-3550(config-if)#no snmp trap link-status
SW1-3550(config-if)#do show run int f0/1
Building configuration...
Current configuration : 171 bytes
interface FastEthernet0/1
switchport mode access
Sundar
Collin Clark
Do you want to disable all traps or just interface up/down? Can you post a "show run | inc snmp" and remove the community?
I want to disable the fastethernet interfaces for up/down and if possible keep the gig trunk ports.
sh run | inc snmp
snmp-server community xxxxxxx RO 66
snmp-server community xxxxxxx RW 66
snmp-server location Somewhere
snmp-server contact Someplace at x12345
I included ACL 66 below....
access-list 66 permit 10.20.50.38
access-list 66 permit 10.20.20.120
access-list 66 permit 10.20.20.121
access-list 66 permit 10.20.50.22
access-list 66 permit 10.20.23.0 0.0.0.255
access-list 66 permit 10.10.21.0 0.0.0.255
access-list 66 permit 10.30.21.0 0.0.0.255
access-list 66 permit 10.24.1.0 0.0.0.255
access-list 66 deny any
Sundar
Sundar...
Thank you so much..... I love ya man!!!
It fixed the issue!!
