Disabling R2D2 interrupt using EEM :5, r2d2_TMC_fatal_intr
cjm000001
Hello
we have N7k , IOS ver n7000-s2-dk9.6.2.12
connected other port due to issued port down (2/6  --> 1/7)
i want to know which problem following the log has.
------# show logging
2015 Aug 29 21:59:45 ------ %R2D2_USD-SLOT2-2-R2D2_SYSLOG_CRIT: Disabling R2D2 interrupt using EEM :5, r2d2_TMC_fatal_intr
2015 Aug 29 21:59:46 ------ %R2D2_USD-SLOT2-2-R2D2_SYSLOG_CRIT: Reset R2D2 asic using EEM to recover from Fatal Interrupt :5, r2d2_TMC_fatal_intr
2015 Aug 29 21:59:47 ------ %MODULE-2-MOD_SOMEPORTS_FAILED: Module 2 (Serial number: 0000000000) reported failure on ports Ethernet2/6 (Ethernet)
 due to R2D2 : Fatal interrupt! in device DEV_R2D2_ASIC (device error 0xc600520f)
------# show interface counters errors
Port          Align-Err    FCS-Err   Xmit-Err    Rcv-Err  UnderSize OutDiscards
mgmt0                 0          0         --         --         --          --
Eth1/1                0          0          0          0          0           0
Eth1/2                0          0          0          0          0           0
Eth1/3                0          0          0          0          0           0
Eth1/4                0          0          0          0          0           0
Eth1/5                0          0          0          0          0           0
Eth1/6                0          0          0          0          0           0
Eth1/7                0          0          0          0          0           0
Eth1/8                0          0          0          0          0           0
Eth2/1                0          0          0          0          0           0
Eth2/2                0          0          0          0          0           0
Eth2/3                0          0          0          0          0           0
Eth2/4                0          0          0          0          0           0
Eth2/5                0          0          0          0          0           0
Eth2/6                0          0         79          0          0           0
Eth2/7                0          0          0          0          0           0
Eth2/8                0          0          0          0          0           0
Port          Giants SQETest-Err Deferred-Tx IntMacTx-Er IntMacRx-Er Symbol-Err
mgmt0              0           0           0           0           0          0
Eth1/1             0          --           0           0           0          0
Eth1/2             0          --           0           0           0          0
Eth1/3             0          --           0           0           0          0
Eth1/4             0          --           0           0           0          0
Eth1/5             0          --           0           0           0          0
Eth1/6             0          --           0           0           0          0
Eth1/7             0          --           0           0           0          0
Eth1/8             0          --           0           0           0          0
Eth2/1             0          --           0           0           0          0
Eth2/2             0          --           0           0           0          0
Eth2/3             0          --           0           0           0          0
Eth2/4             0          --           0           0           0          0
Eth2/5             0          --           0           0           0          0
Eth2/6             0          --           0          79           0          0
Eth2/7             0          --           0           0           0          0
Eth2/8             0          --           0           0           0          0
0 Replies 0
