Disabling / Skipping POST diagnostics on 2960
marcs
I have a situation where I need to decrease the amount of required to boot a 2960 switch. Currently, it's timed at 3.5 minutes. There used to be a "diaglevel" command in CatOS to skip post tests -- is there anything like that in the IOS for a 2960? I'm using 12.2(25)SEE2.
Thanks!
carenas123
Level 5
Level 5
There is no such option on 2960 to reduce the boot time.Performs power-on self-test (POST) for the CPU subsystem. It tests the CPU DRAM and the portion of the flash device that makes up the flash file system. Refer URL
http://www.cisco.com/en/US/products/ps6406/products_configuration_guide_chapter09186a00805a75f0.html#wp1021427
