disabling STP
vishalpatil86
Level 7
Level 7
Is it possible to disable STP in switch??
cadet alain
yes it is but it is highly discouraged. you can use the command no spanning-tree vlan to accomplish this.
Regards.
Alain
For more informations :
https://supportforums.cisco.com/docs/DOC-5180
Best regards,
