disabling wireless on client when connected to LAN
jennyjohn
How can I disable the Wireless on a Client PC (Windows Machine), if it is connected to the LAN via cable. Any way of getting this done automatically.
thanks in advance
Ganesh Hariharan
thanks in advance
You can have this by deploying a centrailsed policy feature of antivirus (Symmantec or Mc Caffe ) updation on your lan client in which you can define to disable the wireless adapter of PC which are connected via wired lan.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
