Display logged messages
sforster123
Hi Community,
the device is triple-stacked WS-C2960S-48LPS-L, IOS 12.2.55 SE7 i've got some issue with 2 connected devices, the show - logging output gives up to ~50 Lines of messages and the Information:
Trap logging: level informational, 38026 message lines logged
How can i display these 38026 messages? Or save/export...
I'm looking for the history, not for the future, using a syslog for example
Thx! Siggi
shaps
Level 3
Level 3
To log to a Syslog server you use,
logging server IPADDRESS
You can verify by using show logging server,
Another way to check the output of logs without syslog is use the | argument and only specify keywords/dates that you are looking for.
show log | inc DDMMYY
