02-19-2018 11:27 AM - edited 03-08-2019 01:55 PM
What two things will a router do when running a distance vector routing protocol? (Choose two.)
A. Send periodic updates regardless of topology changes.
B. Send entire routing table to all routers in the routing domain.
C. Use the shortest-path algorithm to the determine best path.
D. Update the routing table based on updates from their neighbors.
E. Maintain the topology of the entire network in its database.
02-19-2018 12:31 PM - edited 02-19-2018 03:11 PM
It should be A and D,
RIP sends updates after 30 seconds and the updates are considered routing by rumor.
02-19-2018 03:09 PM
Julio
Really??? A Distance Vector protocol uses Shortest Path?
I think this is a poorly written question. I think that clearly choices C and E describe Link State protocols. D is clearly a DV and I believe that the question write meant A to be the other choice but I have problems with the phrase "regardless of topology changes" (think about triggered updates). B looked like a reasonable choice for DV until I got to the part about " all routers in the routing domain" (remembering that DV sends updates only to its connected neighbors.
Rick
02-19-2018 03:11 PM - edited 02-19-2018 03:13 PM
Apologies, I mean: A, that was the reason to mention the 30 sec of RIP.
Fixed, I don't know why I mentioned C hehe
Thank you Richard.
02-19-2018 05:16 PM
Julio
I knew that there had to be an explanation for the response. For a long time I have depended on responses from you to be insightful and correct. This was a major departure from that. Glad that we have got it straightened out.
Rick
02-19-2018 05:27 PM
Thank you so much Richard, I really appreciate that.
Have a great day
02-19-2018 09:57 PM
what about "B". which routing protocol sends its entire routing table to neighbors
02-20-2018 04:16 AM - edited 02-20-2018 04:19 AM
The option B cannot be an answer, it is partially true on distance vector protocols, because currently we have 2 distance vector protocols: RIP and EIGRP, but EIGRP is considered an Advanced Distance Vector protocol, this protocol send changes only, not the entire routing table like RIP does.
So option B is not eligible for an answer.
