Distinguish
rageurdreams
Community Member
Dear all,
what is the difference between "destination unreachable" and "request timeout"?
thak
dgahm
Level 11
Level 11
Request timeout simply means no response was received before the timeout period expired. Destination unreachable is an ICMP message generated by a router that was unable to forward the packet and sent to the source of the packet.
Please rate helpful posts.
Dave
HI,
If a request times out, it means that your computer did not receive a response at all. It's the equivalent of calling someone and having the phone ring hundreds of times until you decide to give up.
The Destination Host Unreachable message means that a router sent you back an error and is equivalent to a busy signal.
PLS Rate if HELPS
Best Regards,
Guru Prasad R
