Distribution switch config, stack or seperate with hsrp
carl_townshend
Hi all
I am installing some new distribution switches on my campus, all access switches will connect to them in the same closet, my question is should I stack them and have L3 vlans running no hsrp, all access switches will have a connection to stack member 1 and 2, so if we lose one switch it will be fine.
Or do I separate the switches, run a trunk between them and have HSRP configured ?
what is the best option?
cheers
Carl
sansarav720e
Hi Carl ,
               What is your Switch Hardware for your new distribution switches , Stacking is mainly meant for doubling your switch bandwidth .
   What is your traffic load from your user access segment . Do you see huge traffic where single hardware cant process your traffic ??
Cisco StackWise technology provides an innovative new method for collectively utilizing the capabilities of a stack of switches. Individual switches intelligently join to create a single switching unit with a 32-Gbps switching stack interconnect. Configuration and routing information is shared by every switch in the stack, creating a single switching unit. Switches can be added to and deleted from a working stack without affecting performance.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_white_paper09186a00801b096a.html
On Distribution layer its always better to run on HA mode with Gateway redudancy protocol .
Santhosh Saravanan
HTH Regards Santhosh Saravanan
