Distribution Switch not working according to default route
shoaib sheikh
Hello All,
I ran into an issue.
User --- acess switch --- Dist Switch ---- Core Switch ---- Firewall ---- Router ---- Internet
Distribution Switch command:
Dist_EB3_EB4#sh run | in ip route 0.0.0.0
ip route 0.0.0.0 0.0.0.0 10.18.88.5
Dist_EB3_EB4#sh ip cef 8.8.8.8
0.0.0.0/0
  nexthop 10.18.88.5 Port-channel252 label 9018
User Machine not able to ping.
ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 8.8.8.8:
   Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Dist_EB3_EB4#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Dist_EB3_EB4(config)#ip route 8.8.8.8 255.255.255.255 10.18.88.5
Dist_EB3_EB4(config)#exit
8.8.8.8/32
User Machine able to ping.
ping 8.8.8.8
Reply from 8.8.8.8: bytes=32 time=17ms TTL=54
Reply from 8.8.8.8: bytes=32 time=18ms TTL=54
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 17ms, Maximum = 18ms, Average = 17ms
The show ip cef has difference of that label 9018 after specific route was placed. But I dont know if this has to do something with LDP.
So to sum up, Distribution Switch ( 6506 in my case and core is 6513 ) is not obeying default route. I know issue is very basic but not able to identify now. 10.18.88.5 is core switch IP .Please help me.
5 Replies 5
Seems some issue with TCAM. Pls share below o/p:
sh ip cef 8.8.8.8 detail
sh mls cef 8.8.8.8 detail
sh mls cef ip 8.8.8.8 detail
Hello Vivek,
Dist_EB3_EB4#sh run | in ip route 8.8.8.8
Dist_EB3_EB4#sh ip cef 8.8.8.8 detail
8.8.8.8/32, epoch 25
  local label info: global/2058
  recursive via 10.18.88.5
    attached to Port-channel252
Dist_EB3_EB4#sh mls cef 8.8.8.8 detail
Codes: M - mask entry, V - value entry, A - adjacency index, NR- no_route bit
       LS - load sharing count, RI - router_ip bit, DF: default bit
       CP - copy_to_cpu bit, AS: dest_AS_number, DGTv - dgt_valid bit
       DGT: dgt/others value
Format:IPV4 (valid class vpn   prefix)
M(362    ):   1     F    2FFF 255.255.255.255
V(362    ):   1     0    0    8.8.8.8
                              (A:180230, LS:0, NR:0, RI:0, DF:0 CP:0 DGTv:1, DGT:0)
Dist_EB3_EB4#sh mls cef ip 8.8.8.8 detail
Dist_EB3_EB4(config)#no ip route 8.8.8.8 255.255.255.255 10.18.88.5
0.0.0.0/0, epoch 25, flags default route
    attached to Port-channel252 label 9018
Dist_EB3_EB4#
What SUP you are using ??
Can you try below in maintanence window:
mls rp ip
ip route 0.0.0.0 0.0.0.0 Port-channel252 10.18.88.5
Hello Vivek,
Raised a TAC for the same. Came to know that Core was advertising 9242 label for default route but Distribution was sending with 9018 label (see my first post ).
He did clear ip route 0.0.0.0 0.0.0.0 on Distribution and it received updated label. So this is cef programming issue.
0.0.0.0/0
  nexthop 10.18.88.5 Port-channel252 label 9242
Core Switch:
show mpls ldp bindings 0.0.0.0 0
  lib entry: 0.0.0.0/0, rev 52
        local binding:  label: 9242
        remote binding: lsr: 3.3.3.3:0, label: imp-null
It all happened because I upgraded core switch image last weekend. Thanks for all help Vivek.
Thanks for the update. Good learning anyways.
