Division of 1 network to a subnettings
yoanna.d
Hello! My task is to divide 1 network to subnetting with IP address 192.168.28.45/28 at 78, 42, 21, and 9 hosts. With this information i todo scheme onpacket tracer with subnetting, switch and ruter. I found this subnettings. My question is how to do scheme on packet tracer with this data. Thank you :)
1/78 host
2^x-2≥78
2^7-2≥78
Host bit = 7
Prefix = 32-7 = 25
Subnet mask = 10000000-> 2^7 -> 128 = 255.255.255.128
Range -> 255-128 = 127 -> 192.168.28.45-192.168.28.172
2/42 host
2^x-2≥42
2^6-2≥42
Host bit = 6
Prefix = 26
Subnet Mask = 11000000-> 2^7 + 2^6 -> 192 = 255.255.255.192
Range -> 255-192 = 63 -> 192.168.28.173-192.168.28.236
3/21 host
2^x-2≥21
2^5-2≥21
Host bit = 5
Prefix = 27
Subnet Mask = 11100000-> 2^7 + 2^6 +2^5 -> 224 = 255.255.255.224
Range -> 255-224 = 31 -> 192.168.28.237-192.168.28.268
4/9 host
2^x-2≥9
2^4 -2≥9
Host bit = 4
Prefix = 28
Subnet Mask = 11110000-> 2^7 + 2^6 +2^5 + 2^4-> 240 = 255.255.255.240
Range -> 255-240 = 25 -> 192.168.28.269-192.168.28.284
9 Replies 9
amsaleka
Wow!! Really a nice Article. Thank you so much for your efforts. Definitely, it will be helpful for others. I would like to follow your blog. Share more like this. Thanks Again.
<a href="https://www.credosystemz.com/courses/iot-training/">iot training in Chennai</a>
what topology in Packet Tracer do you need to apply these subnets to ? Do you have a Packet Tracer project file that you can post (ZIP it first, otherwise the system won't let you upload it)...
I think that should be 4 computers 1 switch and 1 router bit I don't know how to set them up with the data who I have received.
find attached a project file that contains what you have described. Basically, you need 4 Vlans and what is called a router on a stick topology (one router with 4 subinterfaces).
I have created this with Packet Tracer version 7.2, if you cannot open the file, I'll send the configs manually...
Thank you so much and please can you send me configs manually.
Can you tell me how you found IP address who you are used.
here are the configs. The IP addresses are based on your requirements with regard to the amounts of hosts needed per subnet, and are the only way to keep the first three octets (192.168.28.x) and not have overlapping IP address spaces:
IP Addressing PCs
PC0
IP Address: 192.168.28.2/255.255.255.128
Default Gateway: 192.168.28.1
PC1
IP Address: 192.168.28.130/255.255.255.192
Default Gateway: 192.168.28.129
PC2
IP Address: 192.168.28.194/255.255.255.224
Default Gateway: 192.168.28.193
PC3
IP Address: 192.168.28.226/255.255.255.240
Default Gateway: 192.168.28.225
Router Configuration
Router#sh run
Building configuration...
Current configuration : 933 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.28.1 255.255.255.128
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.28.129 255.255.255.192
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.28.193 255.255.255.224
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.28.225 255.255.255.240
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Switch Configuration
Switch#sh run
Current configuration : 1359 bytes
version 12.1
hostname Switch
description Uplink to Router
switchport mode trunk
interface FastEthernet0/2
description Link to PC0
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/3
description Link to PC1
switchport access vlan 20
interface FastEthernet0/4
description Link to PC2
switchport access vlan 30
interface FastEthernet0/5
description Link to PC3
switchport access vlan 40
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Nice blog..! I really loved reading through this article. Thanks for sharing such a amazing post with us and keep blogging... Best React js training near me | React js training online
amsaleka
Nice to good.Also Checkout our website.
