Cannot Telnet or Ping Switches
Scott1sh
Hello everyone
I have a few issues which hopefully i can get some help on
I am trying to ping/telnet onto each switch from the management laptop but i cannot do either
I can ping between the VLAN hosts and servers and switches can ping each other.
The subnet is 172.168.0.0/26 255.255.255.192
I've most likely missed or misconfigured something, i have the flu so brain is a bit fried.
Will post more info if requested
Thanks all
2 Accepted Solutions
Jaderson Pessoa
Dear Scott1sh,
I was check your configurations and in your switch configuration you have a command: switchport trunk native vlan 99, remove it and will works fine.
In your topology.jpg, the connection between swtch1 and r0, interface on R0 has interface in shutdown mode. (turn on interface, please.)
Jaderson Pessoa
*** Rate All Helpful Responses ***
Dear Scott1sh,
Check it, please.
ON R0 Fa0/1: 172.168.2.65
Internet Port Wireless Router - 172.168.2.126 > change port from INTERNET PORT to LAN PORT.
and all will works fine.
Jaderson Pessoa
7 Replies 7
Jaderson Pessoa
Dear Scott1sh,
Jaderson Pessoa
Hi Jaderson Pessoa
Thank you very much i can now ping between the switches, router, servers and PC
However i am still unable to ping from the laptop which is on a different network or telnet remotely
The wireless router is to be configured to use DHCP server with 192.168.5.0/24 addressing
The Non-vlan network is to be 1st and last host of subnet 9 (172.168.2.64-172.168.2.127)
So i could be wrong but
Router 0 = Fa0/1 = 172.168.1.2.66
I have attached the router configuration and the current topology
I know PT can be funny with sending ICMP packets through wireless routers.
Dear Scott1sh,
Check it, please.
Jaderson Pessoa
Got all working now thank you very much for the help
Great.. good lucky =)
Jaderson Pessoa
Duplicate reply
please, if possible, vote as helpful too. thanks
Jaderson Pessoa
