Showing results forĀ
Search instead forĀ
Did you mean:Ā
DMVPN
Network Pro
i am trying to authenticate dmvpn spoke router to hub router using encryption but cant seem to and i get the following errors
what does these errors means?
000075: May 15 18:00:07.242 GMT: %PKI-4-CRLHTTPFETCHFAIL: CRL Request for trustpoint "dmvpn" returned 404 Not Found
000076: May 15 18:00:07.242 GMT: %CRYPTO-5-IKMP_INVAL_CERT: Certificate received from x.x.x.x is bad: CA request failed!
000077: May 15 18:00:09.254 GMT: %PKI-3-CERTIFICATE_INVALID: Certificate chain validation has failed.
000078: May 15 18:00:09.254 GMT: %CRYPTO-5-IKMP_INVAL_CERT: Certificate received from x.x.x.x is bad: certificate invalid
000079: May 15 18:01:11.613 GMT: %PKI-4-CRLHTTPFETCHFAIL: CRL Request for trustpoint "dmvpn" returned 404 Not Found
000080: May 15 18:01:11.613 GMT: %CRYPTO-5-IKMP_INVAL_CERT: Certificate received from x.x.x.x is bad: CA request failed!
000081: May 15 18:01:13.560 GMT: %PKI-3-CERTIFICATE_INVALID: Certificate chain validation has failed.
000082: May 15 18:01:13.560 GMT: %CRYPTO-5-IKMP_INVAL_CERT: Certificate received from x.x.x.x is bad: certificate invalid
000083: May 15 18:02:17.099 GMT: %PKI-4-CRLHTTPFETCHFAIL: CRL Request for trustpoint "dmvpn" returned 404 Not Found
000084: May 15 18:02:17.103 GMT: %CRYPTO-5-IKMP_INVAL_CERT: Certificate received from x.x.x.x is bad: CA request failed!
000085: May 15 18:02:19.238 GMT: %PKI-3-CERTIFICATE_INVALID: Certificate chain validation has failed.
000086: May 15 18:02:19.238 GMT: %CRYPTO-5-IKMP_INVAL_CERT: Certificate received from x.x.x.x is bad: certificate invalid
this is my config whats wrong?
Hub
crypto pki server dmvpn-ca
database level complete
database archive pem
issuer-name CN=x.x.x.x
hash sha256
lifetime crl 168
lifetime certificate 1825
lifetime ca-certificate 2555
cdp-url http://x.x.x.x/cgi-bin/pkiclient.exeoperation=GetCRL
auto-rollover 365 12
database url flash:/DMVPNMain/
database url crl flash:/DMVPNCRL/
database url pem flash:/DMVPNPEM/
crypto pki trustpoint TP-self-signed-337151857
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-337151857
revocation-check none
rsakeypair TP-self-signed-337151857
crypto pki trustpoint dmvpn-ca
revocation-check crl
rsakeypair dmvpn-ca-sshkeys
enrollment url http://10.250.11.1:80
serial-number
ip-address none
password 7 x.x.x.x
rsakeypair dmvpn-sshkeys
Spoke:
enrollment url http://x.x.x.x:80
serial-number
ip-address none
password 7 x.x.x.x
rsakeypair dmvpn
0 Replies 0
