Cisco 3750 web password
Greenchris
Hi all,
Apologies for posting such a newbie question, but I promise I've searched, and I can't find the answer! I simply can't get to the web interface of my 3750 v2.
Here's my running-config. The flash was wiped clean, and I put a new IOS bin (c3750-ipbasek9-mx.122-55.SE11) on there, so it should be factory-new:
Switch#show run
Building configuration...
Current configuration : 1335 bytes
version 12.2
service config
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750v2-24ts
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
interface FastEthernet1/0/2
interface FastEthernet1/0/3
etc...
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
ip address dhcp
ip classless
ip http server
ip http secure-server
line con 0
line vty 5 15
end
interface vlan1 is assigned an address, and when I visit that address I get asked for a username and password. I read somewhere that the username field is ignored, nevertheless I have tried:
cisco:cisco
Cisco:Cisco
blank:cisco
blank:Cisco
If someone can tell me what I'm missing, I'd be grateful.
This is the first time I've actually posted here but this forum has been fantastic for me in my stumbling through cisco kit, so thanks to you all.
Mark Malone
Hi try set the switch up with a password , it uses the switch password for access on web gui
(conf t)username xxx secret xxxx priv 15
(conf t)enable password xxxx
(conf t)line vty 0 4
           login local
That's awesome, thank you. And thank you for not treating me like an idiot, I'm still pretty new to Cisco!
Now off to find out how to install a tar file with a web management interface...
Hooray! :-)
everybody starts somewhere no stupid questions , you will never learn everything that's just the way it is there's too much out there to know it all
this may help with the tar file
https://ccie-or-null.net/2011/05/24/using-the-cli-to-install-and-ios-in-tar-format/
edit .. if you have issues with tftp or ftp pushing image to the switch when your consoled in , turn off your windows firewall temporarily it can block the transfer
