DNS Configuration problem
0iyaaaaaa
Community Member
What is wrong with the following configuration ? its from a skills assessment interview questions.
Host IP Address:172.16.55.36
Subnet Mask:255.255.255.240
Default gateway:172.16.55.1
DNS Servers : 172.18.1.1 , 172.18.1.2
2 Accepted Solutions
John Blakley
The gateway is wrong. It's probably 172.16.55.33.
John
*please rate if helpful*
HTH, John *** Please rate all useful posts ***
lejoe.thomas
Level 9
Level 9
For the
IP address : 172.16.55.36
Subnet Mask: 255.255.255.240
Network Address: 172.16.55.32
Broadcast Address : 172.16.55.47
So the valid host address for the above subnet are (excluding network address and broadcast address)
172.16.55.33
172.16.55.46
The gateway does not belong to this range, which is why way the gateway is wrong.
Likewise you could correct the host address itself so that it is in the same subnet as the gateway.
Lejoe
John Blakley
John
lejoe.thomas
Level 9
Level 9
For the
172.16.55.33
172.16.55.46
Lejoe
