Hi All,
Im fairly new to routing and could do with some help here.
I have a New cisco 881 connected up and its carrying Voice and Data - Voice is working fine but since we removed the old Router on site and connected to the new 881 the only website the PCs can connect to is google.ie, however if you try click on a link it fails. The Server is issuing all the DHCP and the server is able to connect to any websites no problem. If is set the DNS manually on the PC's its working fine but will need to have it left to obtain automatically.
The server is pointing to the ISP's dns directly. I have had a look online and theres a command -"Fixup protocol dns maximum-length 4096" which is for an ASA - theres a simple Firewall in use here on the Router but that command isnt applicable on the 881.
As I said the voice is working fine but just seems to be a DNS issue on the Data side.
Hope you can help.
J-P
