10-02-2013 09:59 AM - edited 03-07-2019 03:48 PM
Having problems with intermittent dns issues can't nail it down on my home network. If you need the config. from the cisco 2950 I can post it also. I'm able to ping by IP so that makes me think it's some sort of icmp related issue. Even webpages seem to load slow. Thanks in advance.
C:\Users\Aadder>tracert www.bright.net
Tracing route to www.bright.net [209.143.0.18]
over a maximum of 30 hops:
1 2 ms 2 ms 1 ms 10.2.40.1
2 4 ms 3 ms 2 ms 10.2.50.1
3 9 ms 9 ms 8 ms 142.254.148.93
4 11 ms 11 ms 12 ms ae0-1258.cr02.clmkohpe.midohio.rr.com [184.59.24
3.125]
5 14 ms 11 ms 11 ms 65.29.1.34
6 10.2.50.1 reports: Destination host unreachable.
Cisco:1841
Building configuration...
Current configuration : 12021 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname R01
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5
enable password 7
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip inspect name CCP_LOW cuseeme
ip inspect name CCP_LOW dns
ip inspect name CCP_LOW ftp
ip inspect name CCP_LOW h323
ip inspect name CCP_LOW sip
ip inspect name CCP_LOW https
ip inspect name CCP_LOW icmp
ip inspect name CCP_LOW imap
ip inspect name CCP_LOW pop3
ip inspect name CCP_LOW netshow
ip inspect name CCP_LOW rcmd
ip inspect name CCP_LOW realaudio
ip inspect name CCP_LOW rtsp
ip inspect name CCP_LOW esmtp
ip inspect name CCP_LOW sqlnet
ip inspect name CCP_LOW streamworks
ip inspect name CCP_LOW tftp
ip inspect name CCP_LOW tcp
ip inspect name CCP_LOW udp
ip inspect name CCP_LOW vdolive
ip tcp synwait-time 10
no ip dhcp use vrf connected
ip dhcp excluded-address 10.2.10.1 10.2.10.10
ip dhcp excluded-address 10.2.30.1 10.2.30.10
ip dhcp pool Vlan20
import all
network 10.2.10.0 255.255.255.0
default-router 10.2.10.1
dns-server 208.67.220.220 208.67.222.222
ip dhcp pool Vlan30
import all
network 10.2.30.0 255.255.255.0
default-router 10.2.30.1
no ip bootp server
ip domain name itsb.local
ip name-server 209.18.47.61
ip name-server 209.18.47.62
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
crypto pki trustpoint TP-self-signed-808243229
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-808243229
revocation-check none
rsakeypair TP-self-signed-808243229
username aadder privilege 15 password 7
interface Null0
no ip unreachables
interface FastEthernet0/0
description Internal Interface$ETH-LAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.1
description Vlan Trunk$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 1 native
ip address 10.2.1.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
no snmp trap link-status
interface FastEthernet0/0.10
description Workstations$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 10
ip address 10.2.10.1 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface FastEthernet0/0.20
description Servers$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 20
ip address 10.2.20.1 255.255.255.0
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface FastEthernet0/0.30
description Wireless$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 30
ip address 10.2.30.1 255.255.255.0
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface FastEthernet0/0.40
description Management$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 40
ip address 10.2.40.1 255.255.255.0
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
interface FastEthernet0/1
description External Interface$ETH-WAN$$FW_OUTSIDE$
ip address 10.2.50.2 255.255.255.0
ip access-group 105 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect CCP_LOW out
ip nat outside
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 10.2.50.1
ip flow-top-talkers
top 10
sort-by bytes
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip nat pool itsbarr 10.2.50.2 10.2.50.2 netmask 255.255.255.0
ip nat inside source list 2 interface FastEthernet0/1 overload
ip access-list standard ACL_NAT
remark CCP_ACL Category=16
permit 10.2.10.0 0.0.0.255
permit 10.2.20.0 0.0.0.255
permit 10.2.30.0 0.0.0.255
permit 10.2.40.0 0.0.0.255
logging trap debugging
access-list 1 remark HTTP Access-class list
access-list 1 remark CCP_ACL Category=1
access-list 1 permit 10.2.40.0 0.0.0.255
access-list 1 permit 10.2.10.0 0.0.0.255
access-list 1 permit 10.2.1.0 0.0.0.255
access-list 1 permit 10.2.20.0 0.0.0.255
access-list 1 permit 10.2.30.0 0.0.0.255
access-list 1 deny any
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.2.30.0 0.0.0.255
access-list 2 permit 10.2.20.0 0.0.0.255
access-list 2 permit 10.2.1.0 0.0.0.255
access-list 2 permit 10.2.10.0 0.0.0.255
access-list 2 permit 10.2.40.0 0.0.0.255
access-list 100 remark auto generated by CCP firewall configuration
access-list 100 remark CCP_ACL Category=1
access-list 100 deny ip 10.2.40.0 0.0.0.255 any
access-list 100 deny ip 10.2.10.0 0.0.0.255 any
access-list 100 deny ip 10.2.20.0 0.0.0.255 any
access-list 100 deny ip 10.2.50.0 0.0.0.255 any
access-list 100 deny ip 10.2.30.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by CCP firewall configuration
access-list 101 remark CCP_ACL Category=1
access-list 101 deny ip 10.2.40.0 0.0.0.255 any
access-list 101 deny ip 10.2.1.0 0.0.0.255 any
access-list 101 deny ip 10.2.20.0 0.0.0.255 any
access-list 101 deny ip 10.2.50.0 0.0.0.255 any
access-list 101 deny ip 10.2.30.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by CCP firewall configuration
access-list 102 remark CCP_ACL Category=1
access-list 102 deny ip 10.2.40.0 0.0.0.255 any
access-list 102 deny ip 10.2.10.0 0.0.0.255 any
access-list 102 deny ip 10.2.1.0 0.0.0.255 any
access-list 102 deny ip 10.2.50.0 0.0.0.255 any
access-list 102 deny ip 10.2.30.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by CCP firewall configuration
access-list 103 remark CCP_ACL Category=1
access-list 103 deny ip 10.2.40.0 0.0.0.255 any
access-list 103 deny ip 10.2.10.0 0.0.0.255 any
access-list 103 deny ip 10.2.1.0 0.0.0.255 any
access-list 103 deny ip 10.2.20.0 0.0.0.255 any
access-list 103 deny ip 10.2.50.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by CCP firewall configuration
access-list 104 remark CCP_ACL Category=1
access-list 104 permit tcp 10.2.40.0 0.0.0.255 host 10.2.40.1 eq 22
access-list 104 permit tcp 10.2.40.0 0.0.0.255 host 10.2.40.1 eq 443
access-list 104 permit tcp 10.2.40.0 0.0.0.255 host 10.2.40.1 eq cmd
access-list 104 deny tcp any host 10.2.40.1 eq telnet
access-list 104 deny tcp any host 10.2.40.1 eq 22
access-list 104 deny tcp any host 10.2.40.1 eq www
access-list 104 deny tcp any host 10.2.40.1 eq 443
access-list 104 deny tcp any host 10.2.40.1 eq cmd
access-list 104 deny udp any host 10.2.40.1 eq snmp
access-list 104 deny ip 10.2.10.0 0.0.0.255 any
access-list 104 deny ip 10.2.1.0 0.0.0.255 any
access-list 104 deny ip 10.2.20.0 0.0.0.255 any
access-list 104 deny ip 10.2.50.0 0.0.0.255 any
access-list 104 deny ip 10.2.30.0 0.0.0.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark auto generated by CCP firewall configuration
access-list 105 remark CCP_ACL Category=1
access-list 105 deny ip 10.2.40.0 0.0.0.255 any
access-list 105 deny ip 10.2.10.0 0.0.0.255 any
access-list 105 deny ip 10.2.1.0 0.0.0.255 any
access-list 105 deny ip 10.2.20.0 0.0.0.255 any
access-list 105 deny ip 10.2.30.0 0.0.0.255 any
access-list 105 permit icmp any host 10.2.50.2 echo-reply
access-list 105 permit icmp any host 10.2.50.2 time-exceeded
access-list 105 permit icmp any host 10.2.50.2 unreachable
access-list 105 deny ip 10.0.0.0 0.255.255.255 any
access-list 105 deny ip 172.16.0.0 0.15.255.255 any
access-list 105 deny ip 192.168.0.0 0.0.255.255 any
access-list 105 deny ip 127.0.0.0 0.255.255.255 any
access-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip host 0.0.0.0 any
access-list 105 deny ip any any log
access-list 106 remark Auto generated by SDM Management Access feature
access-list 106 remark CCP_ACL Category=1
access-list 106 permit ip 10.2.40.0 0.0.0.255 any
access-list 107 remark Auto generated by SDM Management Access feature
access-list 107 remark CCP_ACL Category=1
access-list 107 permit ip 10.2.40.0 0.0.0.255 any
no cdp run
control-plane
banner login ^CWarning Unauthorized Use Prohibited^C
line con 0
password 7
login authentication local_authen
transport output telnet
line aux 0
password 7
no exec
line vty 0 4
access-class 106 in
password 7
transport input ssh
transport output ssh
line vty 5 15
access-class 107 in
password 7
transport input ssh
scheduler allocate 4000 1000
end
