do I need cross over for fiber?
riderfaiz
Hi everyone,
Thank you for your help in advance.
I am troubleshooting a fiber connectivity issue.Now I have two switches, one is 3750, and another is small biz 300 series switch. Both switch has a single mode smf gbic. Now I have two swtiches face to face and connect with a single mode cable. Do you think if I would get a link light on? Both ports are no shutdown.
The reason I said this is that...after a long story, I suspect one of the gbic is bad. Any otherway to tell if my gbic is good or bad too?
Thank you very much.
2 Accepted Solutions
Hameed Shah
I know theres a way to get GBIC statistical and operational information. Ive done this on a 6500 seriess before and it was very beneficial. Im not sure of a direct way to determine if you have a bad GBIC or not simply by looking at it. I was able to issue the commands below while in Priveleged Exec mode. Not to sure if this will even work on the 3750 but depending on the IOS its always worth a shot
show inventory
show inventory raw
But check this Link out
https://supportforums.cisco.com/docs/DOC-5463
FYI not sure if you want to test with some non cisco branded GBICs but these commands will allow you to do so to determine the operational status of the port/interface
service unsupported-transceiver
no errdisable detect cause gbic-invalid
errdisable recovery cause gbic-invalid
You need not to cross.
check that picture and you see how your cable has to look like.
http://commons.wikimedia.org/wiki/File:SFP-front-RX-TX.jpg
Or cisco doc.
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#model3
regards,
Sebastian
pls. rate if helpful
Hameed Shah
show inventory
show inventory raw
Or cisco doc.
regards,
Sebastian
hi,
i actually dont agree with sebastian.
you need to cross one side of the fiber cable as otherwise the transceiving side would connect to the transceiving side and the receiving side would connect to the receiving side. and then you wouldnt get a connect.
one side of the cable must be crossed so its rx on tx.
some cables come already with a little attachment on one side, crossing them by default, but if you cable doesnt have this attachment you have to cross it manually.
