Do Neighbour command work with point to multipoint ospf?
mahesh18
Level 6
Level 6
Hi all,
I was working on my LAB.
Router A  and B are configured with Frame relay - OSPF point to multipoint.
Both have direct connection back to back.
A
Router#sh run int se1/1
Building configuration...
Current configuration : 181 bytes
interface Serial1/1
ip address 192.168.9.3 255.255.255.0
encapsulation frame-relay
ip ospf network point-to-multipoint non-broadcast
no keepalive
Router ospf 1
neighbour 192.168.9.2
B
Router#sh run in se0/1
Current configuration : 157 bytes
interface Serial0/1
ip address 192.168.9.2 255.255.255.0
no keepalive
end
Router ospf 1
neighbor 192.168.9.3
Both routers have nei command configured.
B  Router
Router#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
N/A               0   DOWN/  -           -        192.168.9.3     Serial0/1
OSPF nei is down at both ends.
Serial link is up up at both ends.
I know if i config frame relay map ip command on both ends then
OSPF nei relationship develops.
My question is point to multipoint network back to back serial interface does it work without frame relay map command or not?
Does the neighbour command with with point to multipont?
mahesh
2 Accepted Solutions
Reza Sharifi
Hi Mahesh,
Question: what is router model you are using?
According to this link the neighbor command is only supported on the following platforms:
Platforms
This feature is supported on these platforms:
Cisco 1003, Cisco 1004, Cisco 1005
Cisco 1600 series
Cisco 2500 series
Cisco 3600 series
Cisco 3800 series
Cisco 4000 series (Cisco 4000, 4000-M, 4500, 4500-M, 4700, 4700-M)
Cisco 5200 series
Cisco 7200 series
Cisco 7500 series
Cisco AS5300
If this feature is working on your router, can you apply the same neighbor command with priority and test again?
have a look at this link:
http://www.cisco.com/en/US/docs/ios/11_3/feature/guide/ospfpmp.html
lgijssel
Level 9
Level 9
Hi Mahesh,
The problem you describe is actually not related to the OSPF configuration.
Essentially, what you configured for OSPF is correct on this type of environment.
The problem is with the subnet you chose for the serial link. Because this is a /24, the router cannot determine over which PVC trafic must be sent. (Typical for point-multipoint) So actually your link is not treated as point-point, even though it is connected that way.
When you change the mask on the serial link and configure the routers to be in the same /30, the link will be truly point-point and then it will work without the frame-relay map command.
The point-multipoint scenario you considered will always require a frame-relay map entry.
http://www.cisco.com/en/US/partner/tech/tk365/technologies_tech_note09186a0080094051.shtml
regards,
Leo
6 Replies 6
Reza Sharifi
Hi Mahesh,
Platforms
Cisco 1600 series
Cisco 2500 series
Cisco 3600 series
Cisco 3800 series
Cisco 5200 series
Cisco 7200 series
Cisco 7500 series
Cisco AS5300
lgijssel
Level 9
Level 9
Hi Mahesh,
regards,
Leo
viswamin
Hi Mahesh,
can you pls check if you are able to ping each other. I have a doubt if the ping would work.,
-Vijay
Hi Vijay,
i Can not ping router B  from A
Router#ping 192.168.9.2
Sending 5, 100-byte ICMP Echos to 192.168.9.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Mahesh
Which is additional proof to the explanation provided.
Thanks for reply.
I fig this out if we use
Point to multipoint with non broadcast  we will need frame relay MAP command and also we need atleast 1 nei command
on router.
Also it worked with nei command on each router.
I tested this with 255.255.255 subnet and it worked fine.
Thanks everyone
Mahesh
