Do not worked (backup channel) a "ospf" for ipsec.
Robocop01
Dear All,
No ping from the ip 192.168.10.2 at the ip 192.168.20.3
my file file_for_cisco_packet_tracer
What is it problem?
2 Accepted Solutions
Predrag Jovic
Level 3
Level 3
For start IPsec does not support multicast, which is configured in configuration. OSPF traffic should be placed in GRE tunnel first and then IPsec could encrypt GRE traffic (if neighbors are to be discovered dynamically, as it is configured).
You can find configuration example and explanation - Point-to-Point GRE over IPsec Design and Implementation.
There are other potential solutions (I did not test this one, but it should work) for example, OSPF neighbors can be configured with neighbor command in which case OSPF routers will forward unicast traffic instead of multicast even for hello packets, but I am not sure if that is configurable in packet tracer (maybe it is if serial interfaces are in use on WAN interfaces). There are other potential solutions, for example, IPsec VTI also supports multicast traffic.
Predrag Jovic
Level 3
Level 3
How will add ospf traffic in gre tunnel? Or Do you can offer other solution?
My case
Configuring a Negotiated L2TPv3 Session for an Xconnect VLAN Subinterface: Example
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/l2tpv30s.html
