do we need to use enable secret and enable password for same swithch?
pyihein01
hi do we need to use both enable secret and enable password for same switch?
luis_cordova
Hi @pyihein01 ,
Not necessarily.
The command enable password shows you the password entered in plain text when you check the settings (show running-config).
The enable secret command shows you the encrypted password, which makes it safer.
The interesting detail is that if you enter both commands, the password that the device will request when you log in will be entered with the command enable secret.
Therefore, in reality, it would only be necessary to enter the enable secret command
luis_cordova
Hi @pyihein01 ,
Not necessarily.
thank you and appreciate it.
