04-28-2010 05:18 PM - edited 03-06-2019 10:51 AM
hi,
I am also new to this and will need your help on this.
I have Identify the following for my 4500
Part | Quantity | Cost | Total | Location | Andra Node | Ahus Node | LNG Node | POM Node | Apara Node | 1 spare |
WS-X4516-10GE | 2 | 16821 | 33642 | 10GBPS fibre uplink ports (SM) | 2 | 2 | 2 | 2 | 1 | 2 |
WS-X4424-GB-SFP | 1 | 16881 | GBIC or SFP fibre ports (SM) | 24 | 12 | 24 | 12 | 6 | 12 | |
WS-X4424-GB-RJ45 | 1 | 3179 | 3179 | Gigi Ethernet 10/100/1000 Mbps ports | 24 | 12 | 24 | 12 | 6 | 12 |
SFP LC | 26 | 790 | 20540 | GBIC or SFP fibre modules (SM) | 26 | 12 | 26 | 12 | 6 | |
(20M SM LC– FC) | 10 | 180 | 1800 | Fibre Patch Leads LC - FC | 10 | 10 | 10 | 10 | 10 | |
(20M SM FC – FC) | 5 | 180 | 900 | Fibre Patch Leads FC - FC | 5 | 5 | 5 | 5 | 5 | |
WS-C4507R-E | 1 | 6562 | 6562 | 4507 Chasis | 1 | 1 | ||||
Standalone / 2RU | 2 | 938/2807 | Power Supply 15A | 1 | 1 | |||||
2 | 16340 | 32680 | 10GB SFP for WS-X4516-10GE | 2 | 2 | |||||
WHich IOS will cover licensing for all below and do I only need SMART NET to cover all.
a) Metro Advanced IP feature license (MPLS, EoMPLS, and MPLS VPN; IP Services license).
b) Metro IP Services feature license (BGP, EIGRP, OSPF, IS-IS, PBR, multi-VRF CE, HSRP, PIM, and
DVMRP tunneling; also includes IP Base license.)
c) Metro IP Services to Advanced IP upgrade license
thanks
04-28-2010 06:30 PM
Hi Pius,
There is price difference depending on the feature set you need. You also need a SMART NET contract to be able to download, maintain and upgrade your IOS. Talk to you sales rep.
Reza
04-28-2010 06:55 PM
Thanks will do that...
I have just discovered that I don't think 4500 series support MPLS
Correct me if I am wrong.
