DOD STIG banner too long
ckronk
I'm trying to enter the DOD STIG requred banner on to some 2960's and 3850's, but they both cut off because the last line is too long. Has anyone encountered this previously and what was your work around that passed STIG requirements?
Mike.Cifelli
Try this:
banner motd ^C----------------------LOGIN BANNER------------------------
<Paste in your text>
---------------------------------------------------------------^C
Just play with the formatting. I have configured plenty of 2960s to meet STIG. Good luck & HTH!
Gabe215
Its the weird formatting between word and notepad.  This should work
works on  c3850
switch(config)#banner login ~   <-----------hit enter
Enter TEXT message. End with the character "~"
Then paste
You are accessing a U.S. Government (USG) Information System (IS) that is provided for USG-authorized use only. By using this IS (which includes any device attached to this IS), you consent to the following conditions:
-The USG routinely intercepts and monitors communications on this IS for purposes including, but not limited to, penetration testing, COMSEC monitoring, network operations and defense, personnel misconduct
(PM), law enforcement (LE), andcounterintelligence (CI) investigations.
-At any time, the USG may inspect and seize data stored on this IS.
-Communications using, or data stored on, this IS are not private, are subject to routine monitoring, interception, and search, and may be disclosed or used for any USG-authorized purpose.
-This IS includes security measures (e.g., authentication and access controls) to protect USG interests--not for your personal benefit or privacy.
-Notwithstanding the above, using this IS does not constitute consent to PM, LE or CI investigative searching or monitoring of the content of privileged communications, or work product,
related to personal representation or services by attorneys, psychotherapists, or clergy, and their assistants. Such communications and work product are private and confidential. See User Agreement for details.
