01-03-2017 11:57 AM - edited 03-08-2019 08:46 AM
I have 2 nexus 5ks connected together via port-channel 1. They are not currently configured with a vpc peer-link and my customer decided they now need this function. I want to know if I add the vpc peer-link command to both 5ks if it will cause any type of outage to the current environment? They already have vpc peer keepalive configured, I just need to add the vpc peer-link command to the current port-channel between switches. Once this is configured I'll add the vpc ports as needed.
01-03-2017 12:13 PM
You should probably do this in an outage window, as once you configure the 2 switched as vPC peers, vPC will check for type-1 and type-2 inconsistencies and that can cause outage.
04-26-2017 11:56 AM
shoneycutt - did you ever attempt this? In the same boat.. need to convert to netapp port channels to VPC. I think adding "VPC 20" to the port channel will definitely take down the interface. I just need one of the links to stay up!
