Does CBS350-24T-4X and C1000-24T-4X-L support packet capture?
Roamonkey
I'm working with two Cisco switches: CBS350-24T-4X and C1000-24T-4X-L. I would like to know if either of these models supports EPC (Embedded Packet Capture). If not, are there any alternative ways to capture traffic directly on the switch?
Thanks for your help in advance!
Enes Simnica
hello @Roamonkey Neither the CBS350-24T-4X nor the C1000-24T-4X-L support EPC (Embedded Packet Capture). However u can still capture traffic on these switches using alternative methods like port mirroring (SPAN), which lets u copy traffic from one port to another for analysis. Just check the switch documentation for specific commands, as the setup might vary slightly between models.
also check these links: https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10570-41.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/command_reference/b_1527e_1000_cr.html
hope it helps
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
