04-19-2009 08:12 AM - edited 03-06-2019 05:16 AM
Hi, I have a 3560 switch.
I kept getting this message, " !!! WARNING: The switch is not usable !!!
what should I do? How do I have it fixed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
HTD POST: Basic Test Failed
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
Unable to create l2trace server process, socket_open() failed
Press RETURN to get started!
Thank you for your help
04-19-2009 09:26 AM
Its what it says , its a HW issue . Call cisco and get it rma'd.
04-19-2009 10:00 AM
Thank you for your reply, I don't have the warranty on this switch. What is the ballpark for this repair, thanks!
04-20-2009 03:57 AM
Call cisco think this has a lifetime warranty and a 3560 is not that old of a model. You will need the serial number off the switch.
11-10-2011 10:13 AM
I have the same issue on a WS-C3550-24-PWR in my lab. Reports:
POST: CAM Subsystem Tests : Begin
Address bus test failed for associated data
POST: CAM Subsystem Tests : End, Status Failed
INIT: failed CAM ASIC initialization
And shortly after this:
Reason:
Did you ever get Cisco to replace the switch or? This one is way out of warranty, but if a switch has a lifetime warranty of this failure then I'm glad
Could be nice to be able to do some labs at home.
Thanks.
/JZ
11-10-2011 01:16 PM
3550 is not covered under the new Extended Lifetime Warranty.
03-29-2017 01:59 AM
Hi, I know it's been 8 years but may be it would be useful for others, just change the IOS from ROMMON Mode.
03-10-2022 05:37 AM
I got this message on a WS-C3560G-24T switch. The SYS LED was lighting orange. The system booted into it's Cisco Image but next day when I started it booted into ROMMON. The prompt "swtich:"
One odd thing was the flash didn't have anything on there anymore. And I cant find any donwload for this cisco image on Ciscos website anymore.
03-10-2022 05:53 AM
can you do a flash_init ?
03-10-2022 06:07 AM
Hello sir!
No it wasn't possible to do it. It said it's already initizalied if I remember correct.
And I also could not do
switch:boot
it didn't find any cisco image.
But now I restarted the switch again and now it started to load into the Cisco image that already is installed on the device. It booted up.
Switch#
Switch#
Switch#dir
Directory of flash:/
2 -rwx 1048 Mar 1 1993 00:00:32 +00:00 multiple-fs
3 -rwx 12484113 Mar 1 1993 00:08:51 +00:00 c3560-ipservicesk9-mz.122-53.SE2.bin
8 -rwx 12745998 May 8 2018 10:28:26 +00:00 c3560-ipservicesk9-mz.122-55.SE12.binAfter this I did show version. Looked which one of these two images was running my on switch. (SE12). So I changed it to the SE2 version and currently restarted the switch.
07-24-2025 11:45 PM
i have faced same issue. please help me how to solve this issue
07-25-2025 12:46 AM
Post the complete output to the command "sh post".
07-25-2025 01:40 AM
- @deadzombie786 Your switch has a fatal hardware problem and needs to be replaced (RMA)
M.
