Does Nexus 5500/7000 has limitations on number of trunk ports we could use?
j.boutin
Hi guys,
I am wondering if the nexus platform either 5000/5500 series or 7000 series have some limitations on the number of active trunk ports we could configure as well as passing traffic on them. I haven't find such references in the documentation but I wouldn't be surprised that such limitation exist on one of those platform.
Thank you for your help!
Marwan ALshawi
There is a limit to the number of port channels that you can create
Is there a link where I could find those limitations?
N7k supports 256 vpc port-chanels 16 ports each (8 active, 8 standby)
I think this link will be helpful:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/release/notes/51_nx-os_release_note.html#wp345964
For trunk limitation - here is a gude about supported logical ports which are counted using following formula: (trunk ports) * (vlans configured on them)
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/layer2/configuration/guide/Cisco_Nexus_7000_Series_NX-OS_Layer_2_Switching_Configuration_Guide_Release_5.x_appendix1.html
HTH,
Alex
