Running a script on a switch
Hello
I have been tasked to run a script on a switch.
All I was given was a script.txt file with command line entries in it.
Does anybody know of a way to run this as a script, instead of adding each line one by one in the config?
Edison Ortiz
Copy and paste while in config mode?
Hi Edison,
That could be all they simply mean by 'running a script'.
Thanks for the input!
Yes, fancy term
You can also do the same by copying from a tftp or ftp server into the running config or startup config but if you are already in the switch, a simply copy and paste while in config mode would do.
