05-15-2017 12:49 PM - edited 03-08-2019 10:35 AM
I'm trying to apply an ACL to the SVI to block certain ports as temporary security measure.
Does traffic in the same VLAN go through the SVI, and be subject to the applied ACL, assuming the flows have to go through the L3 switch because it's in the middle of the physical path?
I'm guessing no, because traffic would enter SVI only if it's destined for a different VLAN/subnet, but wanted to confirm.
Thx
Solved! Go to Solution.
05-15-2017 01:05 PM
the short answer is: no. ACLs apply only to routed traffic, not intra-Vlan traffic. To accomplish hosts in the same Vlan to communicate with each other, you need to use VACLs:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/vlan_acls.html#pgfId-1055968
05-15-2017 01:05 PM
05-15-2017 01:14 PM
Thank you so much for the quick response.
Unfortunately our N9K's are not configured to support VACL, so we'll need to look elsewhere to implement this block. (due to TCAM resource regions...we didn't think we'd need to do VACLs)
05-15-2017 01:38 PM
not sure if this is what you are referring to, but on the Nexus 9K, "TCAM resources are not shared when a VACL is applied to multiple VLANs." You should be fine if you apply the VACL to a single Vlan.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/security/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Security_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Security_Configuration_Guide_chapter_01100.html
05-15-2017 01:44 PM
Thank you for the follow-up.
The switch has no TCAM carved to do VACL, so I anticipate if we try to apply a VACL to a VLAN, the N9K would complain there's no memory for it.
When I do "show system internal access-list globals" VACL has no memory reserved...
http://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/119032-nexus9k-tcam-00.html
