Does the Cisco WS-3560G-24TS switch provide POE
pendal8286
Hello all and thanks for your time and expertise.  I think this switch provides POE but can someone provide a definitive answer on this question.  Thank you very much.
ammahend
No it does not however WS-C3560G-24PS does support poe as per 802.3af standard.
More details here
-hope this helps-
ammahend
More details here
-hope this helps-
Thank you for the quick response.  Much appreciated.
I looked at the information you included and it doesn't indicate the switches don't provide POE.  And I believe you but this information should be listed for this switch.
Under PS model do you see “IEEE 802.3af and Cisco prestandard Power over Ethernet”, this feature is not listed under TS model.
Also hope you know these switches are end of hardware support for several several years now.
-hope this helps-
