Does we need to C9400-SSD-240GB on C9400X-SUP-2XL
p
Does we need to C9400-SSD-240GB on C9400X-SUP-2XL ?
@p
"Cisco Catalyst 9400 is a next generation modular switch that supports model-driven programmability, streaming
telemetry, and so on. To support the storage need for these features, the Cisco Catalyst 9400 Series Supervisor
has an M2 connector that hosts a 22x88mm M2 SATA flash card. SATA configuration ranges from 240GB,
480GB to 960GB"
It will depened on your intentions. With those SATA you can extend functionalities lile programmability and application hosting.
5 Replies 5
@p
480GB to 960GB"
If we only running Switching and Routing Function on C9400 So Don't need to for SSD SATA right ?
That's correct.
DRAM
16 GB
16 GB
16 GB
16 GB
Flash
10 GB
10 GB
jackson90
Yes, the C9400-SSD-240GB is required for the C9400X-SUP-2XL as it provides the necessary storage for system operations and configuration.
Leo Laohoo
No, it is not necessary.
