Does WIC-2T & HWIC-2FE work together with 2821?
peterw123456
I have a problem with this issue. Dose WIC-2T(x 2) and HWIC-2FE(x 1) work together in the same C2821? Because when I installed the 2FE in to my router. Powered on, and the lights on the card are lit continuously, also the card is not detected in the router IOS. I have already installed two cards on this 2821 router(WIC-2T). Is there any limitation on these different cards?TKS!
2 Accepted Solutions
Peter,
Please post the full output of these commands here:
show version
show diag
show inventory
Thank you!
Best regards,
Peter
You've just answered your issue.  The HWIC-2FE doesn't work because you are using the wrong IOS version.
12 Replies 12
Peter Paluch
Can you post the output of the two commands show diag and show inventory please? Also, can you try "swapping" the HWIC card so that the HWIC-2FE is inserted into a HWIC slot where a WIC-2T is working? Is the card recognized if all other WIC/HWIC cards are temporarily removed from the chassis?
Also, what is your IOS version? According to the data sheet about the HWIC-2FE at http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html , you need the IOS version 12.4(15)T for this module to be recognized by the IOS.
Best regards,
Peter
Thank you!  Because this router is current in use now. I will try it after 1.5 hours(colleagues will go home) under your instructions.
Thank you so much! Peter!
But I have tried to update the IOS to 'c2800nm-ipbase-mz.124-15.T7.bin'(because Im not familiar with IOS version type) so is it right?
My router's old IOS version is 12.4(3g). I use command "show version" shows the 2fe card is UNKNOWN. But when I use it in new IOS, the card can be find in the "show version". BUT the new FE ports are still cant be find in "show run" or "show ip interface brief". I cant config them.
Peter,
show version
show diag
show inventory
Thank you!
Best regards,
Peter
Dear Paluch
Thanks for you help! I will do this after 30 minites. And then I will reply the details.
Thank you!
Date: Wed, 15 Sep 2010 04:30:08 -0600
To: peter_w_123654@hotmail.com
Subject: New message: "Does WIC-2T & HWIC-2FE work together with 2821?"
peter wang,
A new message was posted in the Discussion thread "Does WIC-2T & HWIC-2FE work together with 2821?":
https://supportforums.cisco.com/message/3180436#3180436
Author : Peter Paluch
Email : peter.paluch@fri.uniza.sk
Profile : https://supportforums.cisco.com/people/paluchpeter
Message:
Does the IOS 'c2800nm-ipbase-mz.124-15.T7.bin' is not the correct one? But the document shows that '12.4(15)T' or later.
I meant this post.
Yes I see. When I update the new version, The router recorgnized 2fe, But I still cant find it in show run and show ip int brief. And all lights are lit. That's the point. Any idea?
peterw123456
I will try for another version. Any result will be posted. Thank you guys!
peterw123456
Dear guys! I have update the IOS version. And the problem have been solved! The version which I renewed is c2800nm-ipbasek9-124-20.T3. Now the WIC-2T(x 2) and HWIC-2FE(x 1) work well in my C2821!
Hi Peter,
I am glad you got it running. Please feel welcome to visit the NetPro forums again!
Best regards,
Peter
