dot 1q on ethernet interface
carl_townshend
Hi all, I saw a config of one of our isp's routers, it has got an interface
int fa 0/1.1000
what would they use this for ?
grichardson661
That is what you call a sub-interface and will be used for ROAS (Router-on-a-stick). Look up - configuring ROAS (Router-on-a-stick) and you will find all the information you need regarding your question.
Cheers,
Garry
I would also look up 'InterVlan routing'
I dont understand why they would need this as the router has got no connection to my lan via a trunk. its simply a wan access router that connects to an e1 line, any ideas ?
