dot1p
rmv72
Level 7
Level 7
Regarding
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/configuration/guide/swvoip.html
#switchport voice vlan {vlan-id | dot1p | none | untagged}
Configure how the Cisco IP Phone carries voice traffic:
•dot1p-Configure the Cisco IP Phone to use 802.1p priority tagging for voice traffic and to use the default native VLAN (VLAN 0) to carry all traffic. By default, the Cisco IP Phone forwards the voice traffic with an 802.1p priority of 5.
I did that -
SW1(config-if)#switchport voice vlan dot1p
% Voice VLAN does not exist. Creating vlan 0
SW1(config-if)#
19:40:29: %PM-2-VLAN_ADD: Failed to add VLAN 0 - VLAN not found.
Does it right behavior or not?
To be honest i don't know but from the preceding notes it does look like that. It would not be the first time that a document had an inconsistency.
I know i have seen configs where there was a voice vlan and it was not vlan 0, in fact i have never seen vlan 0 used in the way the documents suggest.
Unless somebody else can verify one way or another might be best to assume it is a typo.
Jon
10 Replies 10
petrovichr
Community Member
Which is catalyst?
sh ver?
System image file is "flash:c3560-advipservicesk9-mz.122-25.SEE.bin"
Jon Marshall
From the link you provided
"The voice VLAN should be present and active on the switch for the IP phone to correctly communicate on the voice VLAN. Use the show vlan privileged EXEC command to see if the VLAN is present (listed in the display). If the VLAN is not listed, see Chapter 13, "Configuring VLANs," for information on how to create the voice VLAN."
The command you are entering
you are missing out the vlan id ie. the command should be
As the above note states you also need to make sure the vlan already exists in the vlan database. If it doesn't then create it before trying to use it.
Jon
Don't know who rated your post as Resolved but your answer didn't clear that problem...\
Do you offer to create VLAN 0?
VLAN list has range 1..4094
It has nothing to do with vlan 0 because you can't use vlan 0. Pick an unused vlan eg vlan 20. Create this vlan in the vlan database
3560(config)# vlan 20
3560(config-vlan)# name voice-vlan
then you can use vlan 20 in your command ie.
switchport voice vlan 20 dot1p
Have you tried the above.
Jon
Here part of guide-
This example shows how to configure a port connected to an IP phone to use the CoS value to classify ingress traffic, to use 802.1p priority tagging for voice traffic, and to use the default native VLAN (VLAN 0) to carry all traffic:
Switch# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)# interface gigabitethernet1/0/1
Switch(config-if)# mls qos trust cos
Switch(config-if)# switchport voice vlan dot1p
Switch(config-if)# end
There is not vlan number here...
Okay sorry i didn't see that in the link you provided. The default native vlan is usually vlan 1 so i'm a bit confused. Vlan 0 is an internal vlan and is not normally available to be used.
The notes are contradictory because it says the available range is 1 - 4094 and then it talks about vlan 0 carrying the traffic.
I would create a dedicated vlan for voice traffic and try using that in the command as per previous post.
Jon
Do you mean that they wrote it incorrect( forgot to add vlan-id)?
Jon
Thank you!
