dot1q Trunk VLAN MIB
anerdyguy
Is there a MIB that will either tell what ports a vlan is associated to, or a MIB that can help us what ports and vlans are associated?  We are spacifically looking at reporting on trunk interfaces with multiple vlans allowed accross.
Duane R. Anderson
rparames
Hello Duane,
Object       vlanTrunkPortTable
OID      1.3.6.1.4.1.9.9.46.1.6.1
Type      SEQUENCE
Permission      not-accessible
Status      current
MIB      CISCO-VTP-MIB ;   -   View Supporting Images this link will generate a new window
Description      "The table containing information on the local system's VLAN trunk ports."
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.46.1.6.1
Note: the output of the complete table, you can check the link to see the complete MIB treea and see the information that you can poll from it.
Object       vmMembershipTable
OID      1.3.6.1.4.1.9.9.68.1.2.2
Type      SEQUENCE
Status      current
MIB      CISCO-VLAN-MEMBERSHIP-MIB ;   -   View Supporting Images this link will generate a new window
Description      "A table for configuring VLAN port membership.
There is one row for each bridge port that is assigned to a static or dynamic access port. Trunk ports are not represented in this table. An entry may be created and deleted when ports are created or
deleted via SNMP or the management console on a device."
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=vmMembershipTable&translate=Translate&submitValue=SUBMIT&submitClicked=true
If you run that table you will see the following 3 outputs::
Object       vmVlanType
OID      1.3.6.1.4.1.9.9.68.1.2.2.1.1
Type      INTEGER
Permission      read-write
Status      current
Values      1 : static
2 : dynamic
3 : multiVlan
Description      "The type of VLAN membership assigned to this port.
A port with static vlan membership is assigned to a single VLAN directly. A port with dynamic membership is assigned a single VLAN based on content of packets received on the port and via VQP queries to VMPS.
A port with multiVlan membership may be assigned to one or more VLANs directly.
A static or dynamic port membership is specified by the value of vmVlan. A multiVlan port membership is specified by the value of vmVlans."
Object       vmVlan
OID      1.3.6.1.4.1.9.9.68.1.2.2.1.2
Type      INTEGER
Status      current
Range      0 - 4095
Description      "The VLAN id of the VLAN the port is assigned to when vmVlanType is set to static or dynamic.
This object is not instantiated if not applicable.
The value may be 0 if the port is not assigned to a VLAN.
If vmVlanType is static, the port is always assigned to a VLAN and the object may not be set to 0.
If vmVlanType is dynamic the object's value is 0 if the port is currently not assigned to a VLAN.
In addition, the object may be set to 0 only."
Object       vmPortStatus
OID      1.3.6.1.4.1.9.9.68.1.2.2.1.3
Type      INTEGER
Permission      read-only
Status      current
Values      1 : inactive
2 : active
3 : shutdown
Description      "An indication of the current VLAN status of the port.
A status of inactive(1) indicates that a dynamic port does not yet have a VLAN assigned, or a port is assigned to a VLAN that is currently not active. A status of active(2) indicates that the currently assigned VLAN is active. A status of shutdown(3) indicates that the port has been disabled as a result of VQP shutdown response."
HTH,
Rahul
