03-24-2021 07:00 AM
I want to use Wake on LAN on a switch. On the config guide, it says it is supported only on ports configured in 802.1X single-host, multi-host and multi-domain modes. However for switches like C3650 switch, someone mentioned that he succeeded with doing exactly that (I'E configuring WoL with dot1x under a multi-auth port)
Is there any documentation that lists that switches that are capable of doing so? How do I know if my switch is capable of exactly that? I use a c9200 switch.
03-24-2021 09:54 AM
According to this config guide, the feature is supported starting with Cisco IOS XE 3.2SE
See document for config example:
03-25-2021 03:15 AM
Thank you for your reply, but I can't find where Wol and multi-auth are mentioned in the documents.
Can you tell me in what section(s)?
