DOT1X Not Authenticating On Client Restarts
IES Sys Admin
I have DOT1X set up on our C9300 access ports with a MAB backup. The network policy is to authenticate with the computer name and the certificate. If I turn the computer on I get the following error:
DOT1X-5 FAIL: Switch 1 R0/0: sessmgrd: Authentication failed for client (MACADDRESS) with reason (Timeout) on Interface Gi1/0/1 AuditSessionID 13200000000F0000003315ADE30389 Username: host/MONITOR1.DOMAIN.NET
When looking for the authentication session details it says the following:
Interface: GigabitEthernet1/0/1
IIF-ID: 0x1C44F0A1
MAC Address: <computer mac address>
IPv6 Address: Unknown
IPv4 Address: Unknown
User-Name: <computer mac address>
Status: Unauthorized
Domain: UNKNOWN
Oper Host Mode: single-host
Oper Control Dir: both
Session timeout: N/A
Common Session ID: 1F030000400000206FADE9032934
Current Policy: DOT1x
Method Status List:
Method         State
dot1x          Stopped
mab            Authc Failed
If login to the computer I have to go to the network connections windows and it tells me I need to Sign In. It then authenticates. Why is it doing this? Here is one of the port configurations and the are all the same.
switchport access vlan 74
switchport mode access
switchport block unicast
ip arp inspection trust
authentication periodic
authentication timer reauthenticate server
access-session host-mode single-host
access-session port-control auto
mab
dot1x pae authenticator
dot1x timeout tx-period 10
dot1x max-req 3
dot1x max-reauth-req 3
dot1x timeout auth-period 60
storm-control broadcast level bps 62m
storm-control unicast level bps1
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
spanning-tree guard root
service-policy type control subscriber DOT1x_CHECK
 This is Service-Policy
policy-map type control subscriber DOT1x
 event session-started match-all
  10 class always do-all
   10 authenticate using dot1x priority 10
   20 authenticate using mab priority 20
 event violation match-all
   10 restrict
 event authentication-failure match-all
  10 class AAA-DOWN do-all
   10 terminate dot1x
   20 terminate mab
  20 class DOT1X-FAILED do-all
  10 authenticate using mab
 event inactivity-timeout match-all
   10 unauthorize
   20 clear-session
 event agent-found match-all
Mark Elsen
 - @IES Sys Admin    Check logs on the authentication server(s) ,for this authentication (RADIUS, ISE...)
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
What is issue can you more elaborate
MHM
wajidhassan
Level 4
Level 4
This issue usually points to the client not initiating the 802.1X authentication request during startup. What’s likely happening is that the 802.1X supplicant on the machine isn’t triggering properly until a user logs in, which explains why it authenticates after you manually sign in from the network prompt.
Make sure the Windows supplicant is set to authenticate as the computer before user logon. In the Ethernet adapter properties, go to the Authentication tab, and under “Additional settings,” ensure that “Authenticate as computer when computer information is available” is checked.
Also verify that the certificate is present and valid in the machine store, and that there’s no delay in your system's network stack starting up (especially on SSD-imaged or GPO-heavy machines). Finally, confirm your ISE or RADIUS logs, if there’s no attempt shown before login, it confirms the supplicant isn’t starting early enough.
