Dot1x Problem
Jamie Hancock
Level 3
Level 3
We are seeing our wired devices on our Packetfence controlled network being prompted for credentials each time they are plugged in/turned on/rebooted, and often the credentials are being rejected.
Radius debug logs show that Access-Accept is being sent to the device, but the device is not ever getting onto the network.
Enabling debug on my Cisco 2960 test switch I can see the error below:
%DOT1X_SWITCH-5-ERR_ADDING_ADDRESS: Unable to add address
The reason I don’t think that this is a packetfence/radius issue is that we’re not having any issues with wireless clients.
I hope someone can help.
Jamie.
cadet alain
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/system/message/msg_desc.html#wp532108
Alain
Thanks for the reply.
I looked at the MAC address table but it isn't full. I think that error may be a "red herring" because I have debug running on another switch and a user just had the same problem but the "%DOT1X_SWITCH-5-ERR_ADDING_ADDRESS: Unable to add address" didn't appear???
Alain
