DR site
SaeedBakh_2
hi we have main data center included two 6509 core switches with FWMW and IPS,
We want to implement new DR site where we will include 6509 also with the same modules, i do not know how we can architect this new DR and what is required link between the two site main and DR from links and other and how we can achieve the required redundancy in case of main data center failes,appreciate your feedback also if there is any document provide details for such interconnectivity between the main data center and the DR.
the distance between the two site is less than  15 Kilo Meters,and there is fiber between the two sites, so what is the best way to interconnect here because no long distance here and what is the best way in this distance to extend the L2 VLAN extension between the two sites.
if youl would have some Nexus 7000 I woul suggest OTV:
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps9441/ps9402/prod_presentation_otv_intro.html
But as you operate 6500 Catalysts I would prever VPLS:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11_493718.html#wp9000237
And btw, if the interconnection is a Dark Fiber, why not just use a trunk connection?
Michael
Hi Ahmed,
You can use CWDM connectors as a best practice to connect DC and DR sites and you can implemet port channel between those sites over the fibre link.
Pls go through below links.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6575/product_data_sheet0900aecd8029d01b_ps708_Products_Data_Sheet.html
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/VMDC/1.1/design.html
KodandaRao - Please rate helpful posts
