DRAM and Flash memory
rajib_das
Level 2
Level 2
Dear all,
   The default value  of  DRAM and Flash memory are 128 MB and 16 MB of Cisco Catalyst WS-3750-24PS-E  switch .
   I want to know , wherther the deafault value may be change upto 256 DRAM and 128 Flash.
   Thank in advance.
Das Rajib Kr.
Reza Sharifi
No, the 3750 series switches have fixed hardware configuration. Memory and flash can not be upgraded.
If you need a version with more memory and flash, you can use the 3750X series.
Leo Laohoo
Nope.  16 mb flash is NOT upgradable.
