05-17-2012 03:56 PM - edited 03-07-2019 06:46 AM
I'm wondering what the correct process would be to mark traffic for say an snmp monitoring server. I have some links that get over utilized regularly and my snmp traffic cannot make it through and gives me false positives. I have set the snmp-server ip dscp xx on the switches and I can see that the markings are happening and going out of the switch.
snmp-server ip dscp 30
dscp: outgoing
0 - 4 : 172300578 0 0 0 74
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 16853 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 3516 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
So the marking is happening and the traffic is prioritized. Now, what I think is happening is that the snmp server is not getting its requests to the switch because the link is over utilized. So I need to mark the traffic on the server end? This server is on a VMWare host, and I am wondering what the best process is to mark traffic from a guest vm server connected to a 3560?
Set the dscp marking on the server itself and then just trust dscp on the trunk port to the vmware host? Or mark the traffic on the switch using a policy map?
Dan.
05-17-2012 05:18 PM
Maybe you can try something like this:
The default COS coming from the guest vm server is 0 (default). Now, on the uplink port on your 3560, you can try rewriting the COS using:
switchport priority extend cos 5
and see if this helps.
05-17-2012 05:32 PM
Hmmm, don't think I want to do that because there are many more guests on that host and that would mean that all of the guests traffic is marked with cos 5.
