Dual-Active Detection (DAD) link on VSS
uppermost
DAD link prevents both supervisors from becoming active in event of a VSL link failure.
My question is - do I need DAD link. if I have 4 x 100G ports configured as VSL links?
I need other ports for access switches.
My core switch - 9500-24Y4C
It optional cisco recommends but not mandatory.
DAD dont carry any mgmt/control/data traffic  it only use for heartbeat.
Hi @uppermost
 I believe the terminology here might be important.
VSS, VSL and DAD X  StackWise Virtual, SVL
VSS, VSL and DAD is suiltible for IOS device like 6500, 6800, etc.
Stackwise Vitual and SVL is suitible to IOS-XE like 9500,9300,etc
As we are still handling both kind of device and many companies are migrating or preparing to migrate ( 6807-XL Last Date of Support: HW is 2027!) both concept are still present.
But, Stackwise vitual is a new way to perform VSS and it does not required DAD. The link beween devices is now called SVL and it is more like a tradditional stack.
Reading the document for StackWise Virtual we start to see afirmation like "only", "cannot", etc.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-11/configuration_guide/ha/b_1611_ha_9500_cg/configuring_cisco_stackwise_virtual.html
Restrictions for Cisco Catalyst 9500 Series High Performance Switches
  • On C9500-32C switches, you can configure SVL and DAD only on interfaces numbered 1-16 on the front panel of the switch.
  • On C9500-32QC, you can configure SVL and DAD only on native 100G and 40G interfaces (default configuration ports). You cannot configure SVL and DAD on converted 100G and 40G interfaces.
  • In a Cisco StackWise Virtual solution, ports that support 4X10G breakout cables can be used only as data-only ports and cannot be used for configuring SVLs or DAD links.
