Dual ISP automatic failover
wrwiii122
Right now the technician setup our dual ISP connections as a manual cable switch. Does anyone know of a way to make the failover automatic and possible share the load? I know they have devices out there that will do it but we have all Cisco products. Also keep in mind that both have a different public IP blocks from different ISPs.
16 Replies 16
The issue is that Comcast/Time Warner does not do BGP.
Which cable router you are using?
You can use Radware linkproof which can do the active traffic multihoming with the ISP.
http://www.radware.com/content/products/lp/default.asp
-amit singh
