Dual ISP Connectivity using Meraki MX and MS platform
Need High-Level design validation before I implement the attached network on Meraki MS and MX switches.
Also, please refer to the diagram for the following questions:
1. In the event of switch 1 failure and the links on the Meraki Active MX250 goes down, can I trigger a failover to the Passive Meraki?
2. If the AT&T circuit failed; however, my Active Meraki MX will keep sending traffic to AT&T which is a black hole. In this instance, can I do a ping monitor to track AT&T, and if the tracking failed, I want my routes to change to send all traffic over to the TWT ISP? (this should not trigger a fail-over to the Passive Meraki.?
3. Is link Aggregation supported between MS220-24 and MS120-8?
0 Replies 0
